battery problem URGENT
Old Mar 18, 2011 | 08:56 PM
trxblack's Avatar
Default battery problem URGENT
Hello ! I have a Hummer h2 2003 and here is the problem. Today, when I turned off the car, the radio didn't turn off. I thought, maybe if I start the car and shut it down, it will fix. I did that, and it stays turned on. The battery light on the panel, when the engine is working is off but when I stop the engine and remove the key it stays on and the radio too. The battery light stays on. What is the problem?
Old Mar 21, 2011 | 10:26 AM
820larry's Avatar
If I had to make a quick guess, I'd be looking at the ignition switch....
Old Mar 21, 2011 | 01:12 PM
twr1's Avatar
Hi i second that, ign. switches are a com problem with H2
Old Mar 28, 2011 | 08:42 PM
2006h2SUT's Avatar
agreed about the ign switch.. try to wiggle the key next time to fully "lock" it into the off position. try it with the driver door open so the bcm will shut down right away
Old Jan 13, 2014 | 03:29 PM
lionel90's Avatar
Hello,
I have the same issue today with a H2 2003 too: the battery and all the onboard lights stay on when the car is turned off and the key removed, but the battery light off when I start the car.
The battery is OK (12V) and the alternator works fine.
How to verify the ignition switch before ordering a new one ?
Is there any fuse to check ?
Another idea ?
In advance thank you very much for your help.
Old Jan 13, 2014 | 09:47 PM
ak47dennis's Avatar
Originally Posted by lionel90
Hello,
Another idea ?
It's prolly not you ignition switch, it may be you interlock switch on your shifter causing the ignition lock switch lock to activate. Too funny mine did the same thing today (again) I plulled mine out today if tomorrow while out driving around no issues arise I going to keep it out! And then put my steering column covers back on.
Old Jan 14, 2014 | 08:12 AM
calif phil's Avatar
My '03 had the same problem and it was the ignition switch.
Old Jan 14, 2014 | 02:39 PM
lionel90's Avatar
Thank you for your reply.
Please, could you explain how do you disassembled the parts to access the ignition switch ?
maxvis
Oct 22, 2012 12:40 PM
depair
Jan 22, 2010 09:16 AM
raptor0690
Sep 19, 2009 11:27 AM
H1Intercept
Jul 17, 2008 04:02 PM
RyanCodyH3
Jun 9, 2008 09:56 AM
