Edge CTS2 Insight and Evolution, Worth it?
Old Jul 20, 2019 | 11:28 AM
the gauges are digital servos not analogue. best solution is what you intended.... pull the dial and reset its location.
Old Jul 20, 2019 | 02:05 PM
That how I corrected the speedometer on my old truck when I put larger tires on it. Driving with the cluster apart, needle off and used a GPS then stuck the needle back on in the right spot. Worked perfect!
Old Jul 23, 2019 | 10:54 AM
H2-SUT's Avatar
Seems like the easiest and cleanest solution. Its more important they are accurate at operating temperature then when warming up.
I need to pull the cluster anyway to replace led's that are way to blue with some that are ice blue or white. I attached a picture, the photo really doesn't show it but they are almost purple.
I can fix the needles at the same time.
mmesa005
Feb 26, 2018 02:20 AM
H2Miami
Oct 13, 2015 04:29 PM
Threedog
Nov 17, 2013 03:47 AM
No more Jeeps
Mar 11, 2010 12:06 AM
SD90
Oct 24, 2009 01:50 PM
