clean wheel speed sensor hub?
Old Aug 29, 2024 | 07:06 PM
XLRH2's Avatar
Default clean wheel speed sensor hub?
Have a c0040, rf speed sensor.
Found a few vids on gm trucks advising to remove caliper and sensor, clean sensor, put vehicle in neutral and spray in and wipe sensor contacts by turning hub.
Is this possible to rotate hub with just one tire off the ground and h2 in neutral?
Or would I have the lift entire truck to turn one hub in neutral?
Old Aug 29, 2024 | 07:31 PM
Did you inspect the wiring and connector?
Old Aug 30, 2024 | 07:23 AM
calif phil's Avatar
Yes you can rotate the one hub.
johnm724
Dec 1, 2021 02:30 PM
Jbrashers
Feb 19, 2019 09:45 AM
adilaj2002
Aug 3, 2016 10:57 PM
smileynialley
Feb 26, 2015 03:15 PM
mtauseefsa
Jun 19, 2012 09:05 AM
