Speed sensor
Old Aug 29, 2018 | 02:11 PM
Jbrashers's Avatar
Default Speed sensor
Hello, my 2006 h3 has been sitting for a few months. I went to jump in it and it will not shift out of first gear and the speedometer doesn't work. It's a brand new transmission and fluids look good. No codes other than O2 sensors come up. From what little I know that points towards a speed sensor? Does that sound right? If so how do I test that? What should the ohm readings be? Or am I not on the right track?
Old Aug 29, 2018 | 02:31 PM
Have you looked at the speed sensor, is it properly connected, are the wires to it in tact w/o frays or rubbing? Is it turned all the way in?
If the rubber O ring seal to the sensor gets out of its channel, it will not allow the sensor to be seated to the proper depth and will not be able to detect speed.
If you loose a proper connection to the speed sensor (bad sensor, bad wires, dirty connector, connector not snapped into place, of the speed sensor is not fully seated in its hole in the T Case) your symptoms of no speedo with no shift are correct. If the PCM does not know how fast the truck is going, it will not allow the transmission to shift out of first or reverse.
If it looks OK, you could remove it, clean it and the connector w/ electrical contact cleaner, and put it back in to see if it works then.
Old Aug 29, 2018 | 02:36 PM
Jbrashers's Avatar
Ok thanks. I looked at the wires and connector and they looked fine but I did not try tightening it to see if it was in all the way. I just took it out. While it's out till go ahead and clean it and put it back in and ensure its in all the way and see if it works. Thanks again
Old Feb 19, 2019 | 01:36 AM
Monia's Avatar
Where the speed sensor is located?
I have hummer H2 2003, the speedometer does not work and the transmission does not shift to 3 and 4 gear, 2 with problems, 1 and reverse are OK.
Old Feb 19, 2019 | 09:45 AM
You are asking an H2 question in an H3 thread....... asking about apples in the orange thread doesn't work because they are NOT the same thing. Please do not do that in the future.
Davidburke
Hummer H3T
Sep 30, 2024 09:31 AM
jman1335
Jan 26, 2021 06:15 PM
mtauseefsa
Jun 19, 2012 09:05 AM
bheff
Jun 24, 2011 08:41 PM
bheff
Jun 15, 2011 06:35 PM
