help on code c0245
Your wheel speed or ABS sensor is inside your hub assembly. If you have the correct tire size on your vehicle and they are all (4) matching tires then Most likely you have a bad hub bearing (the vibration sometimes causes the sensor too activate.) or the sensor itself is bad. Which side is it on?
hummermongolia
Oct 4, 2015 07:55 PM
Alex2012
Oct 1, 2012 01:53 PM
HumminNBoatin
Nov 24, 2008 01:47 PM
