Caster Angle Opinions Needed
Old Jan 21, 2024 | 05:42 PM
  #21
Originally Posted by Gavin Costigan
-.6 is hardly anything and it’s because the bushing is worn. I can see the cam bolt is completely maxed out. I’ll replace it eventually.
The toe is not ideal but technically in spec so it’s gonna be fine. I can’t yell at them for something that is correct by the book.
idk what’s up with rear toe. They didn’t touch it probably because you can’t. He probably half *** put the rear alignment doo dads on just to make the machine work.
Alignments are performed without passengers, that -.6° will go MORE NEGATIVE with passengers/payload! You will eventually see inner tire wear. BTW, LR camber is also too far negative.
As far as the alignment heads not attached properly, I don't see a before reading to know if they were properly attached to your wheels?
Whatever, it's your ride/tires/$$$$.
zefrum
May 3, 2011 03:57 PM
chrisstaton
Dec 27, 2010 07:08 PM
hollywould
Jul 29, 2009 02:21 PM
ctluba
Nov 19, 2007 09:19 PM
hummer
Jun 3, 2007 02:57 AM
