Caster Angle Opinions Needed
Old Jan 17, 2024 | 07:36 PM
Gavin Costigan's Avatar
Default Caster Angle Opinions Needed
Just got the h2 aligned with the new wheel bearings(it was aligned when the old ones went bad)
this is the printout. The truck pulls left slightly on all roads even crowned but is particularly bad in the left lane on the highway where the road is crowned the other way. It doesn’t take much effort to keep the wheel centered but it is enough that it’s annoying.
With the wheel centered it basically tracks straight within margin of error, but the on center feel is about 3-5 degrees counterclockwise. That’s where it returns to center and likes to stay… yet it goes left at that point.
I’ve heard various things about what caster should be on these trucks. It looks like service manuals call for an ideal .3 degrees more on the passenger side to account for road crown. I’ve got about +.7. Is that enough to be noticeable in the wheel? It is still green on their sheet.
The main questions are here:
Would it be a terrible idea to tell them to make both sides even? Or will I hate how it drives? I do an even mix of left lane highway driving and back road driving. Or should I tell them to make it +.3ish passenger?
Leaning towards just making it even because of how left banked our most highways are here in the southeast.
yes all of my ball joints and bushings are good.
Old Jan 17, 2024 | 08:42 PM
A pull is caused by positive camber or negative caster, in your case you will pull left with both. Your alignment is far off caster and also needs more toe.
Old Jan 17, 2024 | 08:58 PM
Show them the OEM specs. Btw, the secret behind alignment "GREEN" printouts is to simply adjust the oem specs/ tolerance. LOOK AT YOUR CASTER VARIANCE SPECS programmed in to get GREEN.
Old Jan 17, 2024 | 09:00 PM
H2-SUT's Avatar
Gavin, Very interesting, your results are very close to mine. I can say mine drives as straight as an arrow and road crowns don't seem to have any effect unless they are drastic. The only reason I got an alignment was because I bought a new set of tires and wanted to make sure they last. Before I had the alignment done I made sure the Z height and vehicle rake was correct.
Old Jan 17, 2024 | 09:05 PM
https://youtu.be/OVJ39zW0kJg?si=AuTH1yYDkw0m11li
These are the specs I found, they look different from yours. Maybe it’s because caster is measured from ground and not frame. But idk.
also total toe is .10 +- .20 so mine is in spec there.
Old Jan 17, 2024 | 09:16 PM
H2-SUT's Avatar
As you pointed out the specs say something different. I guess I should be happy mine drives as good as it does. My 06 drove a bit better but then again it had Air suspension which I really miss.
Old Jan 17, 2024 | 09:18 PM
Total toe should be +.10°-+.20° LOOK AT THE CENTER LINES:
Old Jan 17, 2024 | 09:22 PM
you have a LOT more caster than I do and they’re within a degree of each other right and left so there’s basically no crown correction going on. If you like the way that drives I might just do the same.
The caster on mine at least on the driver side is looks out of spec by a long shot.
thanks for sharing your actual alignment printout I’ve been looking for one to reference and couldn’t find one.
How did you check/adjust your z-height and rake?
Old Jan 18, 2024 | 12:02 AM
wait… I might be misunderstanding something. If the spec is +.10 +-.20 does that mean anything from -.10 to +.30 is acceptable? or am I wrong?
If my toe is .03 wouldn’t that still be in the accepted range although not the ideal .10?
Old Jan 18, 2024 | 08:10 AM
More positive toe recommended +.10° total.
