broken gear select button
Old Aug 14, 2023 | 08:35 AM
HandsomeSteve's Avatar
Default broken gear select button
hello all new Guy Steve from Alabama.
I've sean on ytube the gear select handle removed an still be able to select gears by pressing down on the vertical piece thats inside the handle.
1st ? the engage button seams to be missing can I stick my finger inside the handle to select gears?
2nd? is there a more durable aftermarket selector available for the H2.
thanks
Old Aug 14, 2023 | 09:54 AM
the button is available through ebay as are used handles.
Old Aug 14, 2023 | 10:07 AM
TeeStu's Avatar
Like Bronxteck said. All over Ebay in many different styles.....
Old Aug 14, 2023 | 10:21 AM
thanks for replys so can I use the finger?
Old Aug 14, 2023 | 11:00 AM
OK I see now that button is a replaceable part of the selector. asking about the finger bc this purchase is site unsean. an would like to drive it home. seller has zero infor.
do you Guys keep spare underneth at trans linkage cable bushing that render the selector unconnected?
thanks
Old Aug 14, 2023 | 03:32 PM
remove the handle off by releasing the allen bolts holding it. some have one some have 2 then you can "use a finger"
Old Aug 17, 2023 | 11:03 AM
the other day I was cruising around in my highly modded 99 trans am.
the gear selector is held into position w/ a c-clip, my handle is loose the clip probally wiggled loose anyway I lifted the handle up off the vertical stem.
I believe this vertical stem is the same as the H2s.will use the finger for initial drive. will test out the TAs handle later.
got this image off net
Old Aug 17, 2023 | 11:06 AM
still cant edit
flashinq
Jul 11, 2022 01:51 PM
Girl_Wonder
Nov 30, 2020 10:55 AM
Lesliemag
Nov 27, 2020 01:54 PM
hummer_on_fumes
Feb 17, 2018 07:17 PM
mrjohnp
16
Oct 6, 2016 05:00 PM
