Hummer H2For those who like a little more gleam to their Hummer, the H2 offers a similar rugged look as the H1, but as a lower cost, and with more added features, making it almost a massive luxury SUV.
So this may be a silly question but when replacing to intermediate lines running to the rear is the one that enters the top of the ABS pump for the right or left side?
Sadly I paid attention while removing from the ABS but really lost track of the rears and the order.
Yes sir. Many thanks. Your video was very helpful going in so many thanks!!!
Completed the job and everything works perfectly. I didnt lift the body so feeding the preformed intermediate lines was entertaining to say the least. Not perfect placement but darn close in the end.
Figure out the lines as the intermediates at the rear have slightly different bends as they enter the connection and it was enough to be fairly obvious which was which had I really look carefully before posting this. Lightbulb went off shortly after.
Stainless. I only did the intermediates and rears at this point. Bought the full kit. My issue was really just the intermediates at the far rear. The fronts are actually not bad so not rushed on those and honestly fairly exhausted just doing the rears I was not sure I had it in me to go all the way. Not planning to delay the fronts to long though. I dont want to live thru a line burst again while on the road. Not fun!
Well you've done the most difficult section, the 4 front lines should prove easier.
SS I feel is the way to go but even though pre-formed, they were not perfect and needed slight adjustments here and there.
Of course please don't delay, looks can be deceptive, my MC1 line split in two, yet on the outside it looked smooth and clean so it must have corroded on the inside probably because the fluid hadn't been changed regularly, if ever.
It's hard to know a vehicles true history, same goes for the transmission etc, etc.,
They’re all a pain in the butt! Replaced everything (pre-bent SS and all 6 hoses) on my ‘03. The only easy way is to do a body lift off. Trying to get the new lines into the clips is the worst.
