04 H2 Abs Pump Module
Old Aug 20, 2022 | 01:01 AM
L3aNo's Avatar
Default 04 H2 Abs Pump Module
Hello Everyone i recently purchased a 2004 H2 and the abs pump module needs to be replaced, unfortunately the part is to far broken to be repaired so i was wondering where is the best place to get a new abs pump module that can ship to Canada? and if any other of GM/Chevy's abs pump modules would fit - thanks
Old Aug 20, 2022 | 08:11 AM
oceanbrave's Avatar
Sounds like you're 100% certain your unit is beyond repair, however it would be good to know what that problem is, and see any photos you may have.
Haven't got lots of experience, but I have had mine on the bench to clean-up and prepare for a complete brake-line replacement job. From the GM service manual it looks like the assembly is in two halves, the Pump Motor Module and ECBM, perhaps you can salvage 1/2 of it or even get the defective bit replaced/repaired (e.g. UpFix)
Searching online they seems to be getting scarce and expensive, as a reference I found this one on eBay at $1.3K, they offer a 90day warranty and I can confirm it's the same PNo as my 2005
On the subject of P/Nos its hard to know which one is which as there are affixed labels and stampings in the aluminum, but this is possibly the correct one 0265219502001
Hope you get what you want ...👍
Old Aug 20, 2022 | 11:19 AM
maybe this company in canada can help
https://xemodex.com/us/product/abs-m...for-hummer-h2/
Old Oct 12, 2022 | 10:48 PM
Rusty_03's Avatar
Determine if it’s the pump or the EBCM. If it’s the pump, like stated. If your lines/connectors are rusted- replace them. Do it now, or have to deal with the royal pita of disconnections and reconnecting AGAIN in the future! If it’s the EBCM, better pray it’s rebuildable. From what I’ve read several places, if it has to be replaced, you get basically 1 chance when reprogramming. Recommendations are to full fuses for EVERYTHING not needing power before attempting reprogramming. There are a few places that rebuild them (with warranty). I need to do this on mine.
Old Oct 13, 2022 | 12:01 PM
many times you can resolder the internal bad solder joints on those older modules.
Hummertime1
Aug 26, 2022 05:28 AM
Nick5263
Apr 8, 2022 09:57 AM
ski.dive
Feb 28, 2019 10:11 AM
achoukair
Jan 14, 2019 12:58 PM
Yuriy Sylovanyuk
Dec 3, 2012 08:53 PM
