ABS Module
Old Apr 6, 2022 | 10:43 AM
Nick5263's Avatar
Default ABS Module
Long shot here but does anyone know where I can purchase an ABS Module for an 03 hummer h2? Thanks
- Nick
Old Apr 6, 2022 | 04:10 PM
hummer_on_fumes's Avatar
Do you still have the original module? Mine wasn't working and I had it rebuilt by Module Repair Pro. Haven't had an issue with it since it was rebuilt which was years ago.
Old Apr 6, 2022 | 05:47 PM
Nick5263's Avatar
I did the same for the original module but it still didn't work. So I bought another used module and was good for about a year, now it throws the same codes as before.
Old Apr 6, 2022 | 08:15 PM
Get your new one rebuilt
Or maybe it's something else?
What are the codes?
Old Apr 6, 2022 | 09:03 PM
Nick5263's Avatar
get your new one rebuilt
or maybe it's something else?
What are the codes?
c0040
c0041
c0046
c0050
c0051
Old Apr 7, 2022 | 06:41 AM
oceanbrave's Avatar
Seems odd to have 2 modules with the same fault codes.
There could be a dodgy connection i.e. loss of voltage of ground, have you checked the 3 fuses ETC/ECM, ABS & EEO, two grounds G308 and G300 and verified these at the connector.
Corroded connector contacts or intermittent crimp/connector wiring?
Appreciate access is very difficult down there.
Old Apr 7, 2022 | 09:36 AM
I agree with oceanbrave. When my EBCM went bad I think I only had code C0896. It doesn't make sense that you had it rebuilt and had the same problem, and then the same problem with another used one. There has to be something else going on
Old Apr 7, 2022 | 11:59 AM
Nick5263's Avatar
Thank you, ill give it a try
Old Apr 7, 2022 | 05:41 PM
DTC C0035-C0051
Circuit Description
As the wheel spins, the wheel speed sensor produces an AC signal. The electronic brake control module
(EBCM) uses the frequency of the AC signal to calculate the wheel speed.
Conditions for Running the DTC
C0035 C0040 C0045 C0050
The ignition is ON.
C0036 C0041 C0046 C0051
Vehicle speed is over 40 km/h (25 mph).
The brake pedal is not pressed.
The ABS is not active.
Conditions for Setting the DTC
One of the following conditions exists for 0.02 seconds:
A short to voltage in the wheel speed sensor signal circuit.
An open in the wheel speed sensor signal circuit.
All of the following conditions exists for 0.01 seconds:
The suspect wheel speed equals zero.
The other wheel speeds are greater than 40 km/h (25 mph) for 0.01 seconds.
The suspect wheel equals zero during drive off, and the other wheels are greater than 18 km/h (11 mph).
A short to ground the wheel speed sensor signal circuit is shorted to ground.
A deviation of 2 wheel speeds at either side of the vehicle greater than 6 km/h (4 mph), or at the front
axle greater than 10 km/h (6 mph) for a time period of 10 to 20 seconds.
Old Apr 7, 2022 | 08:35 PM
how worn out are your tires? do they match?
