Brake issue
Old Aug 15, 2021 | 10:55 AM
Scarey's Avatar
Default Brake issue
2005 H2 Question,
My wife was sitting in the school pick up line for over an hour idling, stop and go. All of a sudden she heard a popping sound, brake pedal went to the floor and lost power steering. I had it towed home and noticed fluid all over the drivers side under the hood. Power steering pump was empty. I refilled it and bled the air out. No leaks to be found. Let it sit about 2 days and now when it starts the brake pedal will go to the floor fairly easily and vibrates when it bottoms out. No lost fluid in steering or master cylinder. I can't figure out how it lost the power steering fluid. Pump and gearbox were recently replaced. Brake pedal has had an intermittent kick back on brake pedal application for some time with occasional abs and traction control lights coming on. Every time I bring it to a shop it doesn't duplicate the issue. I am not sure where to start. Possibly hydo boost issue, or abs module, or both. Any ideas are appreciated.
Old Aug 15, 2021 | 12:20 PM
it does sound like a hydroboost issue kickback on the pedal is one of the symptoms of a failing hydrobooster.
Old Aug 15, 2021 | 04:12 PM
Scarey's Avatar
Could I have somehow lost power steering fluid through the hydro boost?
Old Aug 15, 2021 | 04:23 PM
Scarey's Avatar
Hydro boost, hoses, drivers side shock tower were all soaked with power steering fluid.
Old Aug 15, 2021 | 05:58 PM
Originally Posted by Scarey
2005 H2 Question,
When the hydro-boost fails, you still have braking ability, yet end up with manual braking(no assist). When the master cylinder fails, your pedal will go to the floor, with no braking ability. Inspect your brake fluid for improper fluid contamination. If contaminated, replace master cylinder and make sure to flush the system.
Old Aug 15, 2021 | 06:32 PM
Scarey's Avatar
The brake fluid is good. The brake pedal feels good after it is running for a few minutes. Only after initial start the brake pedal sinks. Bigger question would be how and where did it lose the power steering fluid? It was bone dry in the pump reservoir when initial problems started. Once I refilled and bled the steering system I cannot find any leaks. I degreased the engine compartment today and ran the truck with no leaks. I just can't send the wife driving until I figure this out. Thanks for your input but as of right now it doesn't seem to be a master cylinder issue. I know these trucks are notorious for abs module failure as well but I don't believe that would relate to power steering fluid loss either. Is there a purge valve somewhere on the hydro boost unit that I am not seeing?
Old Aug 15, 2021 | 06:44 PM
How does the brake pedal feel when not running?
You noted brake pedal to the floor, and power steering fluid leak drivers side?
Post some pictures!
Old Aug 15, 2021 | 08:01 PM
Scarey's Avatar
Brake pedal feels good with the vehicle not running as well as while running after a few minutes. It only drops when first started. When it initially had the issue it happened quickly. Something made a popping sound, the Brake pedal went down and lost power steering. I am quite sure the braking issue is directly related to the power steering fluid loss. Once I can figure out what happened with the fluid I am sure the Brake issue will be rectified. I can't see 2 problems happening at the same time but with my luck it may.
Old Aug 15, 2021 | 09:26 PM
Humdinger2
Apr 29, 2023 11:45 AM
RoH2
Aug 15, 2021 12:24 PM
diabloownr
Mar 3, 2011 02:37 PM
sns
Jun 1, 2010 07:42 AM
Sugardaddy
16
Mar 3, 2007 08:09 PM
