BCM removal
Old Jan 25, 2021 | 07:43 PM
Captain T's Avatar
Smile BCM removal
Hi trying to remove BCM on H2 2004 any suggestions.. the workshop manual say the entire dash and steering column need to be removed .. it like it’s been locked in a vault..would appreciate any info.. thanks
Old Jan 26, 2021 | 07:26 AM
oceanbrave's Avatar
Somewhere in this forum you will find details of how to remove the BCM without dismantling the dash
Old Jan 26, 2021 | 07:47 AM
Captain T's Avatar
Smile BCM removal
Thank you for replying.. I actually found this tread after I asked the question.. already have everything apart and fixing to attempt removal.. hope that my nightmare will be over.
Old Jan 26, 2021 | 10:39 AM
fastNYsix's Avatar
what is the issue that is leading you to a faulty bcm?
Old Jan 26, 2021 | 01:00 PM
Captain T's Avatar
I have installed BCM trying to relearn system I on third try.. I had problem with dash lights all on then gauges quit working along with radio windows 4 wd speedometer would also go out have had in three shops dealer really screwed me was there for two weeks said not getting reading from BCM. They closed gmc dealer an sent to ford dealer was told need to replace cables that I have done checked the main ground wires just hope this is my problem.. been two months now trying to fix it. Still can not get it to start any suggestions
Old Jan 26, 2021 | 03:16 PM
if you can get your hands on a used borrowed or china tech2 it will help you with re-programming your modules
Old Jan 26, 2021 | 03:37 PM
fastNYsix's Avatar
Do you still have original bcm? I was unsuccessful with trying to program a used bcm. I was able to at least drive mine with an Escalade bcm after I did the security learn. But ultimately I couldn’t get the Escalade bcm to work 100%. I had to repair the original hummer bcm. My post about bcm removal has a bunch of info on what works and doesn’t work. Might help you. Mine acted weird too when I tried to reprogram the used bcm.
Old Jan 26, 2021 | 04:48 PM
Captain T's Avatar
Well finally got the relearn done for BCM. When started up everything was working now back to square 1 still have my same problems.. dah lights are on then everything goes out all gauges radio window 4WD mirors
I really thought BCM was the problem.. any suggestions..
Old Jan 26, 2021 | 07:11 PM
how new is that starting battery?
Old Jan 26, 2021 | 08:38 PM
Captain T's Avatar
My battery is good had it charging all day while working on BCM. I have been looking at all the wires for a bad connection . I found that the theft control modular electric park light to be very hot just have to touch key an battery lights an cluster have power.. is this normal seems that a wire could be shorting. I give up for a day. Thanks for the help. Just want to say one thing about BCM. If you unplug bottom plug first then you unplug the other 5 plugs you push on BCM forward a little it will come from the back a lot easier than the front.
fastNYsix
Jun 3, 2022 09:38 PM
Vmgreen0110
Nov 1, 2020 02:41 PM
H2008
Jan 13, 2018 11:20 PM
dognut
May 17, 2017 05:59 PM
sterlingmarlin30
Mar 16, 2014 06:32 PM
