HELP! Questions on Fabtech Dirt Logic Shocks with reservoir
Old Jan 26, 2021 | 11:04 PM
Tommy454's Avatar
Default HELP! Questions on Fabtech Dirt Logic Shocks with reservoir
I just got my HUMMER back from the shop with the FABTECH coil spring conversion and I had Fabtech Dirt Loigic shocks installed in the rear as well. Does anyone have these shocks on their H2? Specifically part number FTS800212. According to the Autohance tech rep, there for the rear. 4wheelparts has them listed for the rear. After looking at the order receipt to make sure my part numbers installed matched my receipt from he shop, I found the part number to be FTS800212 on the order and the shops receipt. In the instructions it states FTS80021. So I started researching this part number. This is the only thing I found so far for the FTS80021 part number: http://gatorperformance.com/catalog_.../DirtLogic.pdf.
All online shops that have the FTS800212 part # state it fits my Hummer. 06 base. According to this catalog, these shocks, part number FTS80021 (if its the same part # as FTS800212) is for a 8 inch lift. Does anyone no if this will cause problems on a 6 inch lift? If this is the case???? Also, the catalog doesn't have my GM year for this part number. Also, other online stores (Desert Rat) has them listed as the front shocks (FTS800212) but their pic has no reservoir. The instructions state the shocks come with a Universal Urethane. Does that mean they can be put on the front or rear? Please tell me there is no way you can put a shock made for the front, on the rear of my H2, correct!!?? I drove on some dirt roads and everything seems fine, in and out of 4h 4l and used the traction options. Just what to make sure if anyone can help me out here, I appreciate it. I know.... I need to call FABTECH. too late right now.
On the Fattech website for a 6in lift it stated Dirt logic monotube shocks part number FTS810212. So I thought FTS800212 was the same, but with a reservoir. Mistake I guess. I did call Fabtech before I ordered and he did say they made shocks with reservoirs and I could install them.
Old Jan 27, 2021 | 02:31 PM
Tommy454's Avatar
Just got off the phone with a tech rep from Fabtech. He stated they are for the rear and they can fit and work on a 6in lift H2. Whoosh. Anyone else have these shocks?
tripp1124
Jun 15, 2016 10:46 PM
FLblueH3
Mar 24, 2015 03:05 PM
rockstarbass1
Jan 3, 2015 09:38 PM
MadManMike
Feb 23, 2011 11:38 PM
sinistersix
May 17, 2010 12:42 PM
