Baja LP6 headlights on Hummer H2 – anyone done it?
Old Mar 30, 2026 | 01:40 AM
jjy2kk's Avatar
Default Baja LP6 headlights on Hummer H2 – anyone done it?
Hey guys,
I’ve been looking into running Baja Designs LP6 as primary headlights on my H2, but I haven’t been able to find any real builds or confirmed setups.
I know LP6 has DOT versions and works well on platforms like Jeep Wrangler JK with dedicated brackets, but the H2 is obviously a completely different setup (square housing, bucket mount, etc.).
My questions:
• Has anyone actually mounted LP6 as headlights on a Hummer H2?
• Is there any off-the-shelf bracket solution, or is this 100% custom fabrication?
• How did you deal with:
• mounting depth / positioning
• beam alignment (since LP6 isn’t a traditional projector housing)
• wiring (high/low beam integration)
Right now I’m assuming this would require:
• cutting/modifying the factory headlight bucket
• building custom brackets
• possibly running separate projectors if beam pattern becomes an issue
Goal is more of a clean front-end / show + off-road hybrid setup, not just slapping lights on a bumper.
If anyone has pics, threads, or even “don’t do it” experience, I’d really appreciate it.
Thanks 🙏
Old Mar 30, 2026 | 07:29 PM
tocaguse's Avatar
First, custom fabrication is likely necessary since the H2's headlight housing is quite different from vehicles like the Jeep Wrangler. You may need to modify the factory headlight bucket to create enough depth for the LP6s. For beam alignment, it’s essential to test the positioning after mounting, as these lights don't use a traditional projector design.
Old Mar 31, 2026 | 10:25 PM
tocaguse's Avatar
Originally Posted by tocaguse
First, custom fabrication is likely necessary since the H2's headlight housing is quite different from vehicles like the Jeep Wrangler. You may need to modify the factory headlight bucket to create enough depth for the LP6s. For beam alignment, it’s essential to test the https://tropical-casino.com/ positioning after mounting, as these lights don't use a traditional projector design.
Once you have everything mounted, testing the beam alignment is crucial. Since the LP6s don't use a traditional projector design, you'll want to ensure the positioning is spot on to get the best performance. It might take some trial and error, but with careful adjustments, you should be able to achieve the right setup. Good luck with the project; it sounds like a fun upgrade!
Old Apr 1, 2026 | 07:01 PM
Gavin Costigan's Avatar
Most likely would have to make brackets. I bet it’s pretty easy tho seeing the jeep and h2 are both 7 inch holes. If ur in the Atlanta area I’m sure I could probably fab some up for u.
Briman06
Jun 30, 2024 07:45 AM
Reubensh3
May 15, 2020 09:19 AM
CConNJ
May 28, 2014 07:18 AM
4u33er
Jul 22, 2012 11:32 AM
surfcityred
Nov 8, 2010 10:27 PM
