Bad cooling fan ? .. Whining noise
Old Aug 26, 2018 | 01:46 PM
  #21
Those are the best belts out there you can get in my opinion....
Old Aug 26, 2018 | 07:29 PM
  #22
H2Miami's Avatar
yes I looked in the forum and found that info .
the Acdelco didnt last 2 months without start making noises
Old Aug 26, 2018 | 07:35 PM
  #23
H2Miami's Avatar
Thanks for the info, may I ask is it easy to access e.g. does anything significant need removing like air-intake?
since I just replaced the belts today
I can tell you only the air intake needs to be removed . In my case I didnt have to cause the Airdoc give the needed clearance without having to remove it
if you wants to make it easier then removing the skid plate give you extra clearance from bottom
everything you need is a 15 socket and a ratchet
if you never replaced the belts , tensioner and pulleys then plan ahead and do all
not hard to do and cheap buys on Amazon
Old Sep 2, 2018 | 04:43 PM
  #24
madmayo's Avatar
I would put money on the ac idler tension pulley (not sure if that is correct terminology). I too had that noise last winter and thought it was the fan clutch. Then one day while sitting in a drive thru i could smell burning plastic. Once i got my coffee, i popped the hood and there were little bits of plastic all over the engine. Tried to make it it home and made it a 100ft when the belts popped off.
sorry, just realized the party was already over. Lol
Old Sep 5, 2018 | 08:35 AM
  #25
H2Miami's Avatar
Madmayo
"sorry, just realized the party was already over. Lol"
Very funny
But yes you were right . It was the Ac belt tensioner
thanks
buddy1065
Dec 13, 2019 04:46 AM
woodwardsh3
May 13, 2019 08:03 AM
R1guy777
Dec 28, 2013 09:29 PM
jaymazurk
Oct 5, 2011 10:56 AM
popocamaro1
Feb 21, 2008 05:42 PM
