Airbag Sensor
Old Jun 18, 2025 | 07:31 PM
Henchgt's Avatar
Default Airbag Sensor
Got a great deal in place on my first H2. Color combo I want and under 70k miles. Only issue with the truck is the airbag sensor. Dealer or I can't not find one anywhere. With that being the only issue would you all take the plunge anyway?
Old Jun 19, 2025 | 07:25 AM
oceanbrave's Avatar
@Henchgt
front impact sensor availability has become a major problem.
They usually fail because water and corrosion invade the sensor causing the electronics inside to fail, sadly there are not substitutes yet.
The design is upside-down as mounting tube forms a moisture trap.
Perhaps a used one from breakers yard but be careful to match the part number?
Old Jun 19, 2025 | 10:10 AM
Henchgt's Avatar
Thank-you very much. As an Engineer, that is a very irresponsible design.
Old Jun 19, 2025 | 03:32 PM
dorman sells a replacement if you can find it.
Old Jun 20, 2025 | 04:27 AM
DEA FL's Avatar
I will be moving and need to sell my bike and 06' H2 SUT but my air bag light came one; scan shows a B0103 electronic front end (sensor 2) performance code. Someone mentioned a bad ground but I don't know much about any of this stuff. Replacing a part is easy if its available but tracing ground wires not so much. I looked at my sensor and it appears fine, no corrosion or anything; she is a GA / FL truck. Either way, looks like I'm stuck with an error but how much should that realistically take off from the price of the truck?
hurricane4450
May 29, 2025 10:17 AM
Derek4reaL
Hummer H2 SUT
Feb 16, 2025 07:28 PM
Mike2008
Jan 8, 2025 12:41 PM
Alex DjFlaco
Aug 9, 2021 09:31 PM
HumH3Buff
Jul 9, 2021 07:02 PM
