Air Bag ECU
Old Feb 25, 2020 | 07:44 PM
yeah well they work on e-torx go figure
Old Feb 25, 2020 | 07:55 PM
12pt sockets didn't work well back in the '70's when I first started using them. I have over 1,000 socket wrenches, and I will never use a 12pt. Been "burned" to many times back in the day. Many E-Torx bolts/nuts on the H2 and as those bolts/nuts age, you would be better off with that $16 dollar set that I posted above. My set cost me over $100. and worth every penny.
Old Feb 25, 2020 | 08:10 PM
Booch's Avatar
Anyone know what the cylindrical module in front of seat attached to a bar is ? This item has the three wires pulled out of connector
Old Feb 25, 2020 | 08:37 PM
Posted above by MixManSC. "seat motor"
Old Feb 25, 2020 | 08:44 PM
Booch's Avatar
It’s the item to the far right , I will try to get a good picture of it in am
Old Feb 25, 2020 | 09:01 PM
What does that have to do with your original post:
"Got home from a 3-month trip overseas last night and found my Airbag light is on"?
Old Feb 25, 2020 | 09:06 PM
Booch's Avatar
So I had a problem with Airbag, I was told module was under the seat not knowing what the module looked like I discovered 3 wires had come disconnected from a terminal not knowing what it was at the time I thought it could be related to the airbag. In the past 5 minutes, I learned that this sensor is for the horizontal position driver, I will now remove the seat as directed by others on the forum to check the airbag module as well as fix the disconnected wires from the seat driver.
Thanks to all who have helped so far
Old Feb 25, 2020 | 09:09 PM
looks like a motor. maybe the front / back track motor. the other 2 are probably lift and tilt.
Old Feb 25, 2020 | 09:27 PM
Did you have a SRS failure 3 months ago? How many miles driven in the last 3 months?
Old Feb 25, 2020 | 09:32 PM
Booch's Avatar
3 months ago everything was fine no airbag light . H2 wasnt driven while I was gone
