Aftermarket fuel tank for H2
Old Jul 22, 2020 | 08:42 AM
Jim T's Avatar
Tkx so much.
Old Jul 23, 2020 | 04:38 PM
oceanbrave's Avatar
hummerz thanks for posting the YT videos, really helps with visualization. Is it necessary to have access the pump via the rear wheel arch?
Old Jul 23, 2020 | 05:28 PM
No, that's a New Yorker thing, you will also notice a folding chair on 1 end, and a bucket and step stool on the other end.
If tank is close to empty, you can simply remove a strap while holding the tank, then drop it down a few inches on to a secure platform, go to the other side and do the same. I use hydraulic jacks with plates on jacks, to hold it steady and lower it. Now you have access to remove the lines and connectors. After everything is disconnected, lower it to the ground and go to work with fpm removal, tank cleaning, and new install.
miniLinux
Aug 11, 2014 05:58 AM
mismatch
Sep 3, 2013 01:24 PM
parabat
Apr 26, 2011 11:44 PM
fuellegacy
Oct 24, 2008 07:22 AM
mfish
21
Mar 26, 2008 01:09 PM
