Add a Supercharger at 120k, bad idea?
Old Dec 3, 2019 | 10:54 AM
  #21
mulepic's Avatar
Thanks for the info. The knock sensor for the 6.2L seems different than previous years. It's part number: 12623730 but I can't figure out where on the engine it is located. I'm assuming I need 2?
Old Dec 3, 2019 | 11:25 AM
  #22
coffeydp's Avatar
Yeah my bad, completely skipped over the 6.2 part. In doing a quick look online it looks like the knock sensor (just 1) is on the bottom right side of the block when look from the front. It should be next to the crank sensor. And it looks like it is part number GM 12623730. So then looks like you really dont have anything else to replace while you're in the valley.
Old Dec 3, 2019 | 12:09 PM
  #23
make sure your valley pan bolts are tight and torqued to spec. they sometimes loosen up on the 6.2
Old Dec 3, 2019 | 03:17 PM
  #24
legerwn's Avatar
The thing that I noticed and have seen some posts on the net about on the L92 is the block is cast with the DOD/AFM bosses in the valley (not used). There are seals that fit on the underside of the valley cover to block the oil passages that are known to get hard from the heat and leak causing lower than normal oil pressure. Mine were no exception to this issue, they are not cheap when replaced with OEM parts so if you remove the intake I would at least pull the valley cover and inspect the seals.
Neal
Old Dec 12, 2019 | 10:26 AM
  #25
mulepic's Avatar
@legerwn thanks, I add a new valley gasket to my list of items.
I'm in the process of getting new gaskets for the parts of the install that require the re-use of the original gaskets. I'm having a hard time finding the GM part number for the intake manifold gasket, any help would be appreciated. I did find the MAHLE MS19598 which sounds like it fits, but I'd prefer the OEM if I can get it.
Old Dec 12, 2019 | 12:46 PM
  #26
I'm VERY jealous of that!!
Old Dec 12, 2019 | 01:19 PM
  #27
mulepic's Avatar
Let's see how this goes. I got it to improve towing up hills at elevation. This won't work if heat becomes an issue.
Old Dec 12, 2019 | 01:39 PM
  #28
Sam!'s Avatar
GM parts place i have used for hummer parts
10% Off Shipping
Use code HOLIDAY10 at checkout to save!
Limit 1 coupon per customer. Offer expires 12/12/19.
Old Dec 12, 2019 | 01:43 PM
  #29
mulepic's Avatar
10% Off Shipping
Thanks for sharing, but I still haven't found the 2008 intake manifold gasket part number.
Old Dec 12, 2019 | 02:11 PM
  #30
Fel-pro ms97126
