AC issue
Old Sep 1, 2022 | 01:34 PM
  #21
2004H2's Avatar
Default Scrambled
what year is the H2 with the scrambled ambient temp?
2004 H2
temp at 92 degrees in H3
Old Sep 1, 2022 | 03:14 PM
  #22
2004H2's Avatar
Default Scrambled mirror temp
Originally Posted by ThePtero
Can you elaborate on this? What do you mean by scrambled? I wouldn't ever say my mirror is "scrambled" but it definitely seems to read a lot higher ambient than true ambient.
when you first start the truck the mirror temps shows zeros and directions shows zeros, after about 20 minutes it shows the ambient air temperature and the correct direction, when in the scramble mode it will not go below 60° air temperature coming out of the vents.
once the ambient air and the temperature shows up on the mirror and the truck goes in the full cool mode and goes all the way down to 40° in the daytime….colder at night….
The ambient air probes which is located on the right front fender, under the hood of the vehicle there’s two of them are ones for temperature for the mirror and the other ones for temperature for the trucks a/c unit….
presently my H2 is in the transmission shop for the eighth time, i have lost any confidence in this shop, very disappointed…..
Old Sep 1, 2022 | 09:05 PM
  #23
legerwn's Avatar
There are a lot of unknown variables that need to be known before comparing vent temps. Things like blower speed and recic settings will have a large effect on the vent temps.
I would be interested to know what everyone's superheat (inlet temp vs outlet temp) is on the evaporator coil under charging conditions and at idle (is the suction line cold/sweating back to the compressor), this can help eliminate other components that may be failing. Generally the coil should be flooded with liquid to a certain point then change phases just prior to exiting the coil, this is heavily dependent on the correct charge (and heat load) which can vary depending on the condition of the system.
Neal
Old Sep 1, 2022 | 11:46 PM
  #24
when testing center vent temps the standard is max fan and recirc on with windows down. stated in most shop manuals.
Old Sep 2, 2022 | 08:06 AM
  #25
legerwn's Avatar
I agree, 2004H2 showing center vent temps of 40* we need to know what conditions he is testing to know how they compare with others.
I haven't seen that low of a temp at the center vents of any vehicle with your stated test conditions.
Neal
Old Sep 5, 2022 | 07:59 PM
  #26
ThePtero's Avatar
I haven't had a chance to recheck my pressures again, but what is interesting is that today I was able to reach the green zone at idle, on half fan speed with recirculation (windows up). Granted, ambient temperature was only 73F, but very high humidity as it was raining. BUT...when I started driving at 40MPH with air over the condenser, it actually went up to 48/50F, which seems strange.
Old Sep 7, 2022 | 09:59 AM
  #27
2004H2's Avatar
Default Cooling…
[QUOTE=ThePtero;395729]I haven't had a chance to recheck my pressures again, but what is interesting is that today I was able to reach the green zone at idle, on half fan speed with recirculation (windows up). Granted, ambient temperature was only 73F, but very high humidity as it was raining. BUT...when I started driving at 40MPH with air over the condenser, it actually went up to 48/50F, which seems strange.
[/QUOTEif you want to get better performance from the a/c unit, put a pusher fan on the condenser, unlike old R-12, the best freon ever in my opinion, 134-A is creating more heat at the condenser than R-12, by putting a pusher fan on the condenser will allow for colder air at higher ambient air temperatures…..
today at 4:35, medium high fan speed at 95 degs, 74% humidity, Broward County,Florida…
HeLP
Sep 1, 2022 03:31 PM
Todd Maly
Jul 24, 2020 12:21 PM
mpac165
Jun 4, 2016 04:51 PM
Grunion
Sep 12, 2013 09:46 PM
HummerGuy
Mar 17, 2007 06:37 PM
