3rd Row Single seat stuck locked #2 in 2003 H2 Can anyone show me how manually releas
Old Sep 29, 2021 | 09:19 AM
Fonzie's Avatar
Default 3rd Row Single seat stuck locked #2 in 2003 H2 Can anyone show me how manually releas
I cant get the seat to release from position 2. It is a single 3rd row seat on a 2003 H2. I have watched many videos on Tahoes and Suburbans but is hasnt helped. I can't find or see where the cables go to. I 100% have it down for position one. I have spend a few days soaking it with WD40 because it hasnt been removed in years. When I lift #2 is barely moves just the one side. The other side doesn't move at all. I have tried having someone sit on it while pulling the lever, manually putting screw drivers in there trying to free it. I am guess when you pull the #2 level it operates a cables that releases the other side like what I have seen on Tahoes but the release isn't the same. I watched the videos on how to manually release it and I can even see the other level. Does anyone have a picture of where you can put the screw driver to release it manually? Would someone be willing to lift up there seat and take a picture for me. It doesnt look like any of the seat fabric or leather comes off at all when the seat is in the down position. I would guess the cable is broken or the end piece of plastic is broken but I need to manually release it on each side. Thank you.
Old Oct 2, 2021 | 12:48 AM
finall's Avatar
I sold my 3rd row seat, but remember that it was near impossible to put on or take off. And it was in new condition.
I remember there is some sort of trick where the seat back has to be in a certain position, or the seat can not be disengaged from the floor holds.
Read the manual carefully. I think I remember the seat back has to be fully reclined forward, for the grabbers to disengage. Or something like that.
Then jerked by the seat handle. Anyway, stupid design.
Could that be the problem?
I do not recall any way to "manually" release it. At least not published. Hope someone else may chime in with an intelligent reply.
Old Oct 3, 2021 | 09:42 AM
h2finallyh2's Avatar
When mine got stuck I sprayed it with WD40 around the hinges and any moving parts.
Old Oct 3, 2021 | 09:47 AM
oceanbrave's Avatar
Will send you details later today...
Old Oct 3, 2021 | 09:06 PM
oceanbrave's Avatar
Managed to find this video, it may help you.
Old Oct 3, 2021 | 11:21 PM
HellHoof's Avatar
https://www.youtube.com/watch?v=2BBwNtndYHI
Thanks for posting this. My seat is stuck up - now that I know how lever 3 should move, I can work on un freezing it. Right now it refuses to budge.
Old Oct 9, 2021 | 08:56 PM
Gavin Costigan's Avatar
what i did with that is if you hold back the spring attached to the lever and push the spring and lever down seperately but at the same time it should work. Then spray with wd40 and work it back and fourth.
as for the #2 lever, make sure the front of the seat is securely locked in the mounts. It likely would prevent you from moving the lever if it is not securely locked down.
diyledexpress
Mar 12, 2013 09:44 AM
Jam1962
Sep 28, 2012 09:10 PM
hummer04h2
Mar 7, 2012 01:00 PM
71blackdog
Aug 11, 2010 05:09 PM
SPREAD5150
Jun 29, 2010 09:48 AM
