2nd Battery AGM in vehicle ?
Old Aug 3, 2020 | 04:34 PM
Booch's Avatar
Default 2nd Battery AGM in vehicle ?
I take my H2 out a lot on trails and weekend adventures, with that I run a fridge and some other items I was curious if anyone has put an AGM battery behind the rear interior trim panels? I thought of installing the battery there to include the CTEK 250A DC to DC charger, while accomodating a custom power panel to go where the pocket on the interior panel is. I'm overseas and can't look at my Rig but looking online at pictures under the trim it seems the wheel wells don't have much of an arch in fact they look pretty flat.
Old Aug 3, 2020 | 06:22 PM
agm are spill proof so you can mount them any way you want. even laying down under the rear seats. if you do not have the air ride compressor you can probably fab something there as well save the troubles of removing interior trim.
Old Aug 4, 2020 | 04:37 AM
Booch's Avatar
agm are spill-proof so you can mount them any way you want. even laying down under the rear seats. if you do not have the air ride compressor you can probably fab something there as well save the troubles of removing interior trim.
That option was on my list, I need to take measurements once I get home, I like this option as I can have easy access for the fuse box there too. I hope there is room under one of the seats.
Appreciate the input
Old Aug 12, 2020 | 10:53 AM
Booch's Avatar
Does anyone know if the h2 has body access plugs in the rear passenger or cargo area floor pans, I would go look myself but I'm in Afghanistan till early fall. I'm making diagrams up for my aux battery and wanted a clean install. Thanks in advance
Old Aug 12, 2020 | 11:49 AM
Booch's Avatar
Nevermind I think I found the answer looks like just the spots where the sunroof drains and maybe on the wheel well
Old Aug 12, 2020 | 03:17 PM
thats enough to make a 6 wheeler lol
Old Aug 12, 2020 | 03:51 PM
Booch's Avatar
They want like 1000 bucks for it
Old Aug 25, 2020 | 10:13 AM
Booch's Avatar
Finished designing my two options, everything will be hidden with the exception of the two rear control panels
Old Aug 25, 2020 | 12:53 PM
I'd probably look at hanging a metal battery box underneath by the frame somewhere. Generally not a good idea to have a large battery inside the passenger compartment for safety reasons. I've worked on a good number of ambulances that had aux batteries un a metal box underneath. Pain in the rear to pull it down, especially without a lift though.
Old Aug 25, 2020 | 01:31 PM
Booch's Avatar
I chose the interior location as I didn't think a Fully Sealed AGM would be an issue compared to a Lead acid type, thanks for the input.
ski.dive
Jul 12, 2020 12:07 PM
curleymon
Jan 19, 2019 10:49 AM
DeMopar
16
Mar 11, 2017 06:33 PM
Tech5
Mar 17, 2011 10:32 AM
Theuofmiami
Nov 13, 2010 09:27 PM
