2009 H2 Heater Blows Cold Air When Vehicle Not Moving
Old Jan 6, 2021 | 06:31 PM
CO_Ginger's Avatar
Exclamation 2009 H2 Heater Blows Cold Air When Vehicle Not Moving
Hello.
I have a 2009 H2 and the heater is starting to take a few extra minutes to heat up. The bigger issue I'm having, however, is that the heater starts to blow cool air unless the vehicle is in motion.
Early research on the issue leaned towards the possibility of the thermostat being stuck open, but then I also saw statements about the core needing to be flushed out. I am not a mechanic by any means so any suggestions on how I go about identifying the true cause of this issue and resolving it without having to take it to an expensive repair shop will be greatly appreciated.
Old Jan 6, 2021 | 07:18 PM
Check coolant level
Old Jan 7, 2021 | 02:28 PM
Welcome.
MOVED. All H2 questions go in the H2 section
Old Jan 11, 2021 | 01:28 PM
CO_Ginger's Avatar
Thanks for the assistance. I took the truck in and had them do an oil change and check the coolant level and now it seems to be working properly again.
bigdog100
Jan 3, 2022 02:14 PM
JAC-H2
May 6, 2020 07:47 AM
Mr__Mayhem
May 7, 2017 07:05 PM
sinful7
May 17, 2016 10:28 AM
joenuzz
Dec 5, 2011 11:33 PM
