2003 h2 help! Stranded!!!!
Old Mar 2, 2022 | 10:24 AM
  #21
why cant you cycle the drivers side key is it a wrong cylinder? cycling the key from lock to unlock is usually the master disable for theft deterrent.
Old Mar 2, 2022 | 07:48 PM
  #22
finall's Avatar
@TillysTavern
None of this makes any sense.
1. Do you have the standard OEM alarm that comes with every H2, or some kind of aftermarket system?
2. What is the problem with your driver's door lock? Why has that not been fixed prior to this latest problem?
3. You make it see like you have multiple problems that has just caught up to your neglect of the car. Hope not.
How are the rest of the electronics?
Could be bad lock triggering the alarm?
Old Mar 3, 2022 | 12:45 PM
  #23
legerwn's Avatar
First thing would be to repair the drivers door lock assembly, this is as bronxtech has stated the disarm for the anti theft system.
This is an easy repair that needs to be done and is an integral part of the antitheft system of which your having trouble with.
Place your focus here first, then move on if this does not fix the issue.
Neal
Gomer
Apr 23, 2016 05:02 PM
sypatnode
Feb 20, 2013 10:36 PM
Franky3030
Mar 5, 2010 08:31 AM
meero
Jul 11, 2009 02:43 AM
