2003 H2 Center Brake Light
Old Jul 12, 2019 | 10:48 AM
daniel2b's Avatar
Default 2003 H2 Center Brake Light
2003 H2 … my center brake light (roof mounted) does not work. Can the bulbs be changed or does the whole assembly need to be replaced? Also, how is it removed? I unscrewed the screws but it still won’t lift out. I am hesitant to muscle it … am I missing something?
Old Jul 12, 2019 | 07:16 PM
hummer_on_fumes's Avatar
You have to also take the plastic piece off underneath the light because that's how you unplug the grommet and disconnect the light. I believe the light is both screwed in and 3M taped on. I replaced my entire assembly with an LED rather than trying to fix the original one.
Old Jul 13, 2019 | 09:48 AM
daniel2b's Avatar
Thanks!
Old Jun 25, 2021 | 05:22 PM
syphondog3's Avatar
Dan,
Do you know which light is compatible with it? I have the same problem.
Gomer
Jul 18, 2025 03:44 AM
Gomer
Apr 26, 2016 12:29 PM
depair
Jan 16, 2010 03:38 PM
mbrannon64
Feb 8, 2009 07:04 PM
huntier
Oct 8, 2008 02:44 PM
