05 H2 - vent sensor question
Old Jul 30, 2020 | 06:35 PM
Daniel Z's Avatar
Default 05 H2 - vent sensor question
After taking the dash apart and exposing the vents, I noticed that the driver and passenger side have some type of an insert/sensor plugged in to the vents. Does anyone know what these are called or have a part number? Discovered these when I was removing the door blend actuator; the one that people can't get to (well I was able to remove it without cutting or damaging anything in the process). Just curious what these are and what their function is. Thanks.
Old Aug 3, 2020 | 09:25 AM
Daniel Z's Avatar
I suppose this is the culprit that's causing hot air blowing on the drivers side. The cracked gear. This is located on the passenger side bottom near the center console. Let's see if I can get a replacement part as opposed to paying over a hundred for a new part.
Old Aug 4, 2020 | 02:32 PM
That is and the large gear is what cracks just as yours did and causes it to fail.
oceanbrave
May 27, 2019 03:08 PM
oceanbrave
May 27, 2019 11:18 AM
hummer_on_fumes
Dec 2, 2018 05:51 PM
ash
Nov 14, 2013 03:18 PM
Hooty-Hoo
Sep 2, 2011 11:26 PM
