05 H2 Break booster
Old May 7, 2022 | 06:31 AM
Daniel Z's Avatar
Default 05 H2 Break booster
another leak equals another project and replacement. Break booster started to leak recently so it’s time for a new unit (coming in today). Well it started to leak back late last year but now it’s a lot worse. need to revisit my other thread for info
on a side note, added these cheap stickers to the roof rails. Looks alright though.
Old May 7, 2022 | 07:51 AM
calif phil's Avatar
Stickers look good on there.
Old May 16, 2022 | 05:36 AM
Daniel Z's Avatar
Default Update
Finally got to work on the truck and replaced the booster. Overall it’s a fairly straightforward job. A few cuts and bruises, a few f bombs. Hardest part was getting the retaining clip off the break pedal and that one bolt right behind the break pedal. The C clip was not original to the truck and it was tough to get it off with limited access.
next project - power steering gear box and new exhaust that’s been sitting on my shelf for months.
cheers
This clip was a pain to remove due to access. If it was the original one I think that would come off a lot easier.
Old and new. The gasket was actually the wrong part but made it work.
Old May 16, 2022 | 09:08 AM
Nice - yeah I can only imagine getting that c-clip off was fun. Even the stock style clip will make you curse some though. It is just a stupidly awkward place to try and get at. You really need to get both hands on things which is extremely difficult up there under the dash. Having a set of wobble extensions and universal joints for sockets does make the bolts a bit easier but that top one is still a pain regardless as well. The rest of it is pretty easy and straightforward.
Old May 16, 2022 | 09:33 AM
Daniel Z's Avatar
agree 100. I’m 6-1 about 220lb and it was not easy to position myself right. Now not sure what to do with the old one. I might get the rebuild kit and learn how to fix the leaks and see the inner workings. Maybe I can use it when I get another H2 we shall see.
Old May 16, 2022 | 10:25 AM
i gave my old one to a friend that was resto mod'ing an old chevy, i also gave him my old lines and power steering pump since it was a matched set. he resealed it with the kit.
Old May 16, 2022 | 11:34 AM
I rebuilt mine. It started leaking again after a few months. So I bought a brand new (not a rebuild) one.
Old May 16, 2022 | 01:12 PM
Daniel Z's Avatar
yeah I’ll give it a shot and see what happens. I’m all for brand new stuff myself to have that piece of mind but I’ll take a stab at rebuilding once in a while. One thing I have learned, always get OEM parts too, even as simple as a switch.
Zco
Apr 15, 2022 04:18 PM
NCH2
Jan 1, 2015 06:49 PM
jmen0619
Nov 7, 2014 09:27 AM
norinco3264
Oct 31, 2013 10:29 AM
medicman
Jul 16, 2013 10:24 PM
