1997 6.5LT rear differential leaking at input between draft shaft and differential.
Old Feb 18, 2025 | 07:01 PM
ljclarke1's Avatar
Default 1997 6.5LT rear differential leaking at input between draft shaft and differential.
Need the specific set of parts needed to replace the seal and or bearings for full service. Only has 80k miles on it but leaking, not bad but can see where gear oil is coming out.
Old Feb 19, 2025 | 07:50 AM
Talk to Dave Oberer at www.hummerpartsguy.com. He can fix you up with everything you need.
bauerb
Oct 23, 2024 10:24 AM
Cathairez
Aug 29, 2022 07:43 PM
Goinvertical
Jun 24, 2010 01:52 PM
trich24
May 15, 2010 11:11 PM
trich24
May 15, 2010 12:13 AM
