1994 H1 fuel tank
Old May 30, 2019 | 06:12 PM
Sempervet's Avatar
Default 1994 H1 fuel tank
Hi everyone. Before I ask my question let me start by saying I did search the forum and did not find what I needed. That being said if I missed something please let me know. So I purchased a 1994 civilian H1 that was used for hummer tours. Long story short, the fuel tank was gone when purchased. I have a tank for a 94 that had no components and I am slowly buying everything it needs. I also have a complete tank from a 1996, but was told I would need to change the fuel lines to make it work. Is this true? From what I can tell all the tank is is pick up and return tubes and some breathers. Can anyone verify if I can use the 1996 tank or if I should just continue building the tank from the 1994? Thanks for any help with this.
Old May 31, 2019 | 01:30 PM
I think the harness for the tanks are different. Check with Dave at www.hummerpartsguy.com. He can tell you what you need.
Old May 31, 2019 | 03:06 PM
Sempervet's Avatar
Thanks I will ask him. As far as I csn tell the only harness is for the sending unit. The pump is on the motor
Old Oct 27, 2019 | 09:18 PM
Sempervet's Avatar
Just wanted to update. I used the tank from a 96 h1 in my 94 and after a little air bleeding from the system she fired right up. All I did was extend the soft fuel lines to reach the pick up and return tubes. Plus it made it easier to install the tank.
Old Oct 28, 2019 | 07:56 AM
Cool. Glad you got it worked out...and cheaply.
Elvin Knight
Apr 15, 2018 01:34 PM
miniLinux
Aug 11, 2014 05:58 AM
CARdiac
Oct 5, 2013 11:00 AM
wordupmag
Jan 21, 2012 07:17 AM
acheron800
Jan 4, 2011 04:11 PM
