turn key and won't crank
Old Oct 16, 2019 | 04:28 PM
Lord Farquuad's Avatar
Default turn key and won't crank
hey guys, I have a 2000 H1 was sitting for a 4 months, just put in 2 new batteries and tried to start it and nothing. it wont crank or make any noise. I got underneath and checked voltage to the starter and it was getting 15.11 volts. i'm thinking maybe that means the starter is bad but just want to make sure could it be anything else or is there another way to verify its the starter?
thanks
Elias
Old Oct 16, 2019 | 07:08 PM
smack it with a hammer a few times it might free it.
Old Oct 16, 2019 | 07:36 PM
LOL, Works every time if you hear a click? Old school way, is to jump the solenoid with a screwdriver.
Old Oct 16, 2019 | 07:41 PM
make sure to use your most hated screwdriver!!!
Old Oct 16, 2019 | 07:49 PM
Like this guy?
Old Oct 16, 2019 | 07:53 PM
Hammer test with a click:
Old Oct 17, 2019 | 02:45 PM
haha, thank you for the videos Hummerz, I will pull the starter out this weekend and try this. i'll get back to you guys with what I found. hopefully a bad connection, these starters are not cheap.
Old Oct 17, 2019 | 06:09 PM
just cause it spins out side the truck without engine load does not mean it is working properly or reliable. it might spin but not have the torque to spin the engine properly. but usually its the starter solenoid has bad contractors connecting the starter motor internally from my years of experience or bad, worn or sticking brushes.
Old Oct 17, 2019 | 08:54 PM
Most common is a voltage loss to the starter.
If it comes down to the starter failure:
Old Oct 21, 2019 | 01:37 PM
Most good starter/alternator shops will rebuild one for $125.00 or less.
