H3 2006 transmission install.
Old 09-30-2019, 10:01 PM
Adrianandy's Avatar
Default H3 2006 transmission install.
I have been working on a 2006 h3 first it was just to change the shift solenoid out then after inspecting the pan the transmission was toast there was metal and tranny fluid was black and burnt.there was a high rev after 35mph so the owner bought another transmission to be installed so I installed the transmission everything went on smooth but after all said and done started it up let it warm up and then attempted to shift in reverse ...nothing. Drive ...nothing all gears no shift at all..so we went over again with a fine tooth comb lol attemted again to no surprise still no shift in any form ..what can it be ?fluids are on spot ..
Old 09-30-2019, 10:06 PM
did you reuse the torque converter?
Old 09-30-2019, 10:18 PM
Adrianandy's Avatar
No not the same one from the old tranny we used the one from the transmission he bought.
Old 10-01-2019, 11:40 AM
then maybe the replacement transmission has a failed pump. you might have to check the line pressures.
Old 10-01-2019, 05:43 PM
RKSmith163's Avatar
Is your Transfer Case in Neutral? Simple things first.
blharty
07-18-2016 08:28 AM
ollied
11-08-2014 01:22 PM
rsm688
11-06-2014 05:28 AM
stinger95
02-05-2011 08:51 AM
HummerH2
03-13-2008 12:04 PM
Quick Reply: H3 2006 transmission install.
