What size lift for 35's and 22x14's with a big offset.
Here is basically the same thing. Instead of 35s, they are 325/50r22s with a negative 76
offset.
As the video says, it's going to stretch the tire out just a hair with 325s.... a 35" tire is going to be 12.5" wide or about 315ish.
If you're going with a 14" wide tire, I'd consider going 335, but that's going to stick out like crazy. Maybe 22x12 would be a good compromise?
offset.
offset.
https://www.youtube.com/watch?v=L5-VXZ-SjYg
offset.
I am running 38x15.50 on a 17x10 inch wheel with a zero offset. I have a 3 inch lift in the back because of spacers, I have maybe a 2-2.5 inch lift in the front because of upgraded keys.
I dont rub unless I am locked at full turn.
I also have MT tires so the **** catch everything when I am at full lock.
I think you will be ok.
Given a six inch lift with 35s or 37s might make them look really small.
My 3 inch make that truck look tight.
Get compliments all the time
Caraddict
18
09-19-2012 07:06 PM
Ranks44
12-15-2010 08:22 AM
importkiller
06-22-2006 02:59 AM
