What size lift for 35's and 22x14's with a big offset.
Old Oct 4, 2016 | 09:42 PM
brock sapp's Avatar
Default What size lift for 35's and 22x14's with a big offset.
I'm worried about the tore rubbing the out side of the fender because of the offset.
Old Oct 5, 2016 | 08:45 AM
No idea what vehicle you have.
Old Oct 6, 2016 | 02:19 PM
brock sapp's Avatar
2004 h2
Old Oct 7, 2016 | 10:53 AM
What's a "big offset"?
Old Oct 7, 2016 | 10:36 PM
Synthetickiller's Avatar
Here is basically the same thing. Instead of 35s, they are 325/50r22s with a negative 76
offset.
As the video says, it's going to stretch the tire out just a hair with 325s.... a 35" tire is going to be 12.5" wide or about 315ish.
If you're going with a 14" wide tire, I'd consider going 335, but that's going to stick out like crazy. Maybe 22x12 would be a good compromise?
Old Oct 9, 2016 | 01:08 AM
brock sapp's Avatar
offset.
https://www.youtube.com/watch?v=L5-VXZ-SjYg
I have a fab tech 6 inch lift coming in for it soon. And was just wanting the 14 wides with the -76 offset. I already have some 37's for the 22x14 wides but I'm worried it will rub, not on the inside but on the black plastic fender trim.
Old Oct 15, 2016 | 07:57 PM
jsbihn's Avatar
I am running 38x15.50 on a 17x10 inch wheel with a zero offset. I have a 3 inch lift in the back because of spacers, I have maybe a 2-2.5 inch lift in the front because of upgraded keys.
I dont rub unless I am locked at full turn.
I also have MT tires so the **** catch everything when I am at full lock.
I think you will be ok.
Given a six inch lift with 35s or 37s might make them look really small.
My 3 inch make that truck look tight.
Get compliments all the time
Old Oct 16, 2016 | 10:12 AM
jsbihn, have you ever posted your H2? I don't think I've ever seen it. It sounds bad *** though.
Spuds
Jan 24, 2013 06:07 PM
Hummer79
Jan 7, 2013 11:28 PM
Caraddict
18
Sep 19, 2012 07:06 PM
Ranks44
Dec 15, 2010 08:22 AM
importkiller
Jun 22, 2006 02:59 AM
