What size lift for 35's and 22x14's with a big offset.
I'm worried about the tore rubbing the out side of the fender because of the offset.
No idea what vehicle you have.
Originally Posted by TAINTER
(Post 339376)
What's a "big offset"?
Here is basically the same thing. Instead of 35s, they are 325/50r22s with a negative 76
offset. As the video says, it's going to stretch the tire out just a hair with 325s.... a 35" tire is going to be 12.5" wide or about 315ish. If you're going with a 14" wide tire, I'd consider going 335, but that's going to stick out like crazy. Maybe 22x12 would be a good compromise? |
Originally Posted by Synthetickiller
(Post 339418)
offset. As the video says, it's going to stretch the tire out just a hair with 325s.... a 35" tire is going to be 12.5" wide or about 315ish. If you're going with a 14" wide tire, I'd consider going 335, but that's going to stick out like crazy. Maybe 22x12 would be a good compromise? https://www.youtube.com/watch?v=L5-VXZ-SjYg |
I am running 38x15.50 on a 17x10 inch wheel with a zero offset. I have a 3 inch lift in the back because of spacers, I have maybe a 2-2.5 inch lift in the front because of upgraded keys.
I dont rub unless I am locked at full turn. I also have MT tires so the nobs catch everything when I am at full lock. I think you will be ok. Given a six inch lift with 35s or 37s might make them look really small. My 3 inch make that truck look tight. Get compliments all the time |
jsbihn, have you ever posted your H2? I don't think I've ever seen it. It sounds bad ass though.
