H2 windshield noise
It is the trim on either side of the windshield. They are held in by screws and the weather stripping attaches at the bottom by a small notch. Remove them, clean the old rubber and attach double sided tape, foam, caulk, whatever you want then reinstall the trim pieces. Wind noise gone.
Wind noise
Good morning. Unclear on where the phone/double-sided tape/sealer goes? Does it go on the inside of the trim that I remove two for the hand flapping against the glass? Thank you
Yes, the part that rests on the glass. I believe there should be some old rubber or foam on there already. It gets pressed down over time and the trim will begin to rattle. I just put 3M double sided foam on mine and never had the issue again.
hulkh3
09-12-2012 08:02 AM
jman_in_minnesota
11-24-2007 06:44 PM
carissa
04-18-2006 12:48 AM
