H2 windshield noise
Old Oct 7, 2016 | 07:34 AM
OCFDfyrfytr's Avatar
Default H2 windshield noise
H2 windshield noise. Tremendous wind noise on both sides of windshield, at the A post. Any thoughts,. Bad gasket re-seal gasket etc. Extremely loud. Thanks
Old Oct 7, 2016 | 07:52 AM
mcioci's Avatar
It is the trim on either side of the windshield. They are held in by screws and the weather stripping attaches at the bottom by a small notch. Remove them, clean the old rubber and attach double sided tape, foam, caulk, whatever you want then reinstall the trim pieces. Wind noise gone.
Old Oct 7, 2016 | 08:07 AM
calif phil's Avatar
I put a bead of Permatex Ultra black silicone on my 2003 windshield trim and it fixed it perfectly.
Old Oct 7, 2016 | 02:21 PM
H2CANEPADESIGN's Avatar
Ditto what phil said. it solved the problem.
Old Oct 11, 2016 | 11:49 AM
Default Appreciation thank you spot on
Thank you you were spot on
Old Oct 11, 2016 | 11:50 AM
Default Spot on
Old Oct 20, 2016 | 09:01 AM
Default Wind noise
Good morning. Unclear on where the phone/double-sided tape/sealer goes? Does it go on the inside of the trim that I remove two for the hand flapping against the glass? Thank you
Old Oct 20, 2016 | 10:16 PM
LoJac963's Avatar
Yes, the part that rests on the glass. I believe there should be some old rubber or foam on there already. It gets pressed down over time and the trim will begin to rattle. I just put 3M double sided foam on mine and never had the issue again.
hulkh3
Sep 12, 2012 08:02 AM
bigsteelerfan36
Sep 16, 2010 04:12 AM
jman_in_minnesota
Nov 24, 2007 06:44 PM
carissa
Apr 18, 2006 12:48 AM
efrainl956
Mar 22, 2006 05:14 AM
