Yet another V8 swap
Old Jan 28, 2018 | 02:58 PM
madpickinskills's Avatar
Default Yet another V8 swap
Hello. New member here. So the 3.5L in my 2006 went out. Actually I accidently helped it. So instead of rebuilding the 3.5 I decided to swap it with a 5.3L. I've read some of the threads where other people have swapped to an LS2, LSA, etc, but since I'm in California and they limit what you can do, I decided to get an engine that is as close to the 5.3 they put in the alphas. The donor car is a 2013 Tahoe. According to the pictures I've seen, they are pretty much physically the same (accessories, brackets, etc) but the main difference with the Tahoe engine is 1) It's flex fuel 2) it has AFM as its an LMG code engine. Another issue is the Tahoe had a 6 speed trans.
The Tahoe engine came with everything to do a swap. Even the gas pedal. Not the trans.
The Wiring harness: Would it be easier to keep the 3.5 harness and ecm and have them modified, or modify the Tahoe harness, or buy a harness from an alpha?
Old Jan 29, 2018 | 10:27 AM
Does it have the correct oil pan? If not, it ain't goin in.
Old Jan 29, 2018 | 01:25 PM
And trans pan to clear the front prop shaft, and a new trans cross member and, and, and...
Old Jan 29, 2018 | 04:42 PM
emetdw's Avatar
Is the Tahoe motor aluminum block?
j e f f x o 6 x
45
Aug 17, 2007 07:42 AM
Voodoo
Mar 16, 2007 11:43 PM
CCMDoc
Dec 6, 2006 11:24 AM
khoolhandz
Aug 30, 2006 08:01 PM
2luke2
Jun 12, 2006 10:03 AM
