Fault codes got me lost
Old Jan 26, 2018 | 07:39 PM
Flatbed224's Avatar
Default Fault codes got me lost
Hey y'all, still working on this 07' H3. The fault codes are listed below, anyone got the slightest idea of what this might be?
fault codes-
p0171 em
p0013 cam shaft actuator
p0102
p0300
p0365 cam shaft position
u1401
u1064
c0240
c0208
b0790
u1000
please help! Lol
Old Jan 27, 2018 | 09:20 AM
Happy Hummer's Avatar
I'm at a loss with this thread lol...
What are some of the things you've all ready done?
Old Jan 27, 2018 | 12:51 PM
Flatbed224's Avatar
well it all started 2 weeks ago with bad fuel mileage, then it went to a check engine light and then the feeling of the transmission slipping. I ran the fault codes and then it was p0014 I think. Cleaned the vvt actuator, the cam sensors, put new plugs in, oil change and left the battery terminals off for 2 days. I put the terminals on and fired her up, she ran like she was brand new. 40 miles later everything came back, this time with 20 times the amount of codes as before.
Old Jan 28, 2018 | 01:53 AM
Chimpy's Avatar
For starters, replace the factory battery cable ends/terminals.
Old Jan 28, 2018 | 05:11 AM
Flatbed224's Avatar
yeah, I did that in August. Other than that and the occasional normal wear and tear part, this beast is 100% stock
Old Jan 28, 2018 | 06:41 AM
sycraft's Avatar
replace the VVT actuator, if its going bad, cleaning does not help. I replaced both cam and crank sensor and VVT actuator and no issues since. All cheap, use ACDelco only
Old Jan 28, 2018 | 12:09 PM
Chimpy's Avatar
fault codes-
p0171 em
p0102
p0300
u1401
u1064
c0240
c0208
b0790
u1000
please help! Lol
The p0171,0102, and 0300 could be a vacuum leak around the intake or at the throttle body.Don't know what to say about the communication "u" codes.
The "c" chassis codes have to be ABS related.
Old Jan 28, 2018 | 01:05 PM
Flatbed224's Avatar
any easy way to tell if the vvt sensor is bad?
Old Jan 29, 2018 | 01:37 PM
Ummm, you get codes. Which you stated above you have.
Old Jan 29, 2018 | 02:54 PM
Flatbed224's Avatar
ok replaced the actuator just to find out after installing it that you can out 12v to it and it should click and move, good way to test if it's bad...turns out though mine wasn't bad, still got the problem. Codes did Jack didly on that one, any other smart *** answers you've got I'd love to hear.
