Will a navigation unit plug into my factory harness
Old Jun 25, 2009 | 01:38 PM
vital velocity's Avatar
Default Will a navigation unit plug into my factory harness
I have the bose unit in my 03 h2....if i buy the navigation head unit....will it plug directly into my harness?
Old Jun 25, 2009 | 10:58 PM
Quijy's Avatar
it should, but you will need the GPS antenna that goes in the dash.
I just happen to have both a bose NAV radio and the GPS antenna that I have removed. if you are interested let me know. I have the NAV disk and two working copies. this unit and GPS antenna came out of my 2005 H2
once installed, your dealer will have to unlock the radio security lock out and allow the carr to read the GPS.
Old Jun 26, 2009 | 07:36 AM
calif phil's Avatar
You will also need to tap the VSS wire in the speedo cluster and run it to the NAV/ Radio connector. I did this same install on my 03 and I love it.
Old Jun 30, 2009 | 06:50 PM
AT6Stick's Avatar
the factory nav unit may or may not work in your H2 it depends on the type of amp in your car. there are class2 and non class2 models, research before you buy
karaokejunkie_5
Jul 10, 2014 09:23 AM
CRIMSON
Nov 7, 2010 03:55 PM
h2hummer03
Oct 21, 2010 03:12 PM
nate_b
Mar 7, 2007 11:31 PM
jm4490
Dec 30, 2006 05:38 PM
