Where's the radiator drain petcock?
Old May 17, 2011 | 02:05 AM
skeeet's Avatar
Default Where's the radiator drain petcock?
I think I looked all over for it. Does the H3 have a radiater drain petcock? Is there an engine drain plug?
I
Old May 17, 2011 | 09:43 AM
JCA1981's Avatar
From: The Empire State... should be called The Nanny State
There is none. With coolant service intervals much higher now I believe they've done away with them or so that's how I understood it. If you are doing a drain/flush of the coolant system, you might want to check this thread out:
https://www.hummerforums.com/forum/h...pletely-23791/
Old May 17, 2011 | 09:49 AM
JCA1981's Avatar
After taking a second look, I just realized you started the thread I posted above to try to help out. Sorry, didn't put 2 & 2 together until now. Doc explains there why the H3 doesn't have the radiator drain plug though and how to change the coolant.
Hope your thread helps... lol
Old May 17, 2011 | 11:33 AM
Draketh's Avatar
How about the 5.3L? Does it have one? I'm going to need to wrap up all of my 50k service soon.....
Old May 18, 2011 | 01:02 PM
JCA1981's Avatar
I'm unsure about the V8 application. Any Alpha owners out there change their coolant yet?
Also, might want to check what's talked about in this thread while you're changing the coolant/poking around the radiator:
https://www.hummerforums.com/forum/h...-leaked-21184/
Mad Professor
Jan 16, 2025 08:13 AM
DOC4H
Aug 16, 2017 07:59 AM
Antonio Dom.Rep.
Jun 24, 2008 11:23 AM
josh1899
Mar 22, 2008 10:52 AM
HummerfromClemson
Dec 29, 2006 10:12 PM
