Weird wobble
Old Jan 15, 2015 | 07:05 PM
4Scargo's Avatar
Default Weird wobble
So I've got a wobble in the front on my '06. It wobbles, pulling to the left when I am going slow below 35-40 mph. Sometimes when I put on the brakes it pulls rather hard to the left. Now, it only does this when it is wet.
Any idears?
Old Jan 15, 2015 | 07:11 PM
hum4me's Avatar
Any idears?
check brakes, wheel bearings to start with
Old Jan 16, 2015 | 09:16 AM
4Scargo's Avatar
Thanks Hum....should have added that what's I thought. Replaced the pads and rotors, then an old garage sage said it was the belts in the tire, switched it out, too. Doesn't seem to be any wobble in the hub when it's on the lift. Half shaft is new. Maybe the steering rack?
I'm stumped!
Old Jan 16, 2015 | 10:03 AM
hum4me's Avatar
did ya check the ball joints when you put in the half shaft? upper&lower
Old Jan 16, 2015 | 10:18 AM
hum4me's Avatar
hope it is that and not the differential might want to start looking into that
Old Jan 16, 2015 | 10:32 AM
badss98's Avatar
If your front end is all tight you can check your steering shaft for play,The rag joint in the middle of the shaft fails all the time and is a common replacement.Remove drivers wheel and you will be able to see it and grab it and see if there is excessive play
Old Jan 16, 2015 | 06:33 PM
4Scargo's Avatar
Thanks guys, but it only does this when it's wet. I know, I know, but that's the truth. Live in MN and I first noticed this before Christmas in a thaw. Now we are in a January thaw, same thing. Doesn't do it when the roads are dry or snow covered. Only when it's wet. Maybe a sticking brake piston in the caliper? Has me stumped.
Old Jan 17, 2015 | 07:47 AM
hum4me's Avatar
Hopefully one of our fellow hummer owner has experienced the same situation and can help ya out . keep us updated really like to know whats doing it.
Old Jan 19, 2015 | 09:22 PM
4Scargo's Avatar
Thanks again, guys. Roads are dry now, no wobble. The plan is to adopt a 'wait 'n see' attitude. I'll update if it rears it's wobbly head.
ukpaul
20
Jul 13, 2010 07:31 PM
CRXMA22
20
Dec 13, 2007 02:35 PM
azz7772
Sep 28, 2007 02:02 PM
gardj
35
Dec 16, 2006 05:22 PM
Sugardaddy
27
Nov 13, 2006 12:52 PM
