Water pump help
Old Sep 18, 2015 | 02:04 PM
Jesslucy's Avatar
Exclamation Water pump help
I am wanting to replace my water pump, I was told if I replace it, I should replace the timing belt as well. Is this true or not? 2004 hummer h2 with 105600 miles on it.
Old Oct 8, 2015 | 11:43 PM
coowboy701's Avatar
I am not a Tech,but I think your motor has a timing Chain !!
Old Oct 10, 2015 | 08:00 AM
calif phil's Avatar
No timing belt on your 6.ol and the timing chain does not need to be replaced.
Old Oct 11, 2015 | 01:25 PM
H2Miami's Avatar
I replaced the water pump a few weeks ago .. Water pump had nothing to do with timing at all .. Maybe your misunderstood timing belt and the fan belt
I replaced the AC belt cause was worn , Also make sure you get a new thermostat and to follow the torque specs .
Very easy job , only hard part was to remove the Fan .. Need to rent a tool from autoparts
Old Jul 3, 2023 | 12:05 AM
MadDogBimmer89's Avatar
What temperature were you running before you did all that? What do you think fixed it or did you just replace all the stuff at once?
R1guy777
Dec 28, 2013 09:29 PM
williecee
Dec 13, 2011 03:19 PM
dizzy
23
Feb 21, 2011 09:15 PM
jstdoitt21
17
Jan 31, 2008 02:25 PM
Dennis C
Sep 5, 2007 07:35 AM
