Water in my Dash
Old 10-01-2018, 07:04 PM
jjaguilar's Avatar
Default Water in my Dash
Hi, I have a H3 Hummer 2008.
When I start it up, begin moving forward, or quickly decelerate I can hear a lot of water moving from one place to another under the dash or maybe just behind the firewall.
I think that my AC Drain Line y Clogged but I cant find the Line.
Old 10-01-2018, 09:12 PM
norinco3264's Avatar
Do you have a moonroof?
The drains are known to become clogged and trap water.
Are the door's drain holes open?
Old 10-01-2018, 09:25 PM
jjaguilar's Avatar
I unclogged the drain lines of the sunroof but in the dash still a lot of water.
A day ago I sent the H3 to a car wash, I think water enters to the dash because the drains are clogged.
Door drain ?
Old 10-02-2018, 08:32 AM
The is no place "in the dash" to hold water, but the HVAC box is in front of that. Check your coolant.
Otherwise, it is your sunroof, and there is a set of front and rear drains that need more than unclogging, they need the sunroof drain fix per the thread here and vids per Google search.
Old 10-02-2018, 08:52 AM
jjaguilar's Avatar
When I start the AC sounds like air is making bubbles in the water.
Old 10-02-2018, 08:53 AM
jjaguilar's Avatar
Old 10-04-2018, 06:59 AM
Broken Halo's Avatar
Sounds like the drain opening for your A/C evaporator is plugged (you know, the puddles you always see under the vehicle when the A/C is on and you're at a stand still), and the housing has filled with condensation water. That's why you're hearing sloshing, and when the blower is on it's blowing bubbles.
Old 10-04-2018, 08:19 AM
jjaguilar's Avatar
How I fix it ?
Old 10-04-2018, 09:05 AM
Originally Posted by jjaguilar
How I fix it ?
By looking it up on Google would be a start. The drain comes out of the firewall on the passenger side under where the AC lines go into the HVAC exchange box.
mhc100g
Hummer H3T
07-31-2019 03:38 PM
KingJoseph
03-11-2014 09:28 AM
mgurgone
10-31-2011 10:16 AM
radioactivesob
04-19-2011 07:22 PM
HummerGerhardt
11-01-2009 07:56 PM
Quick Reply: Water in my Dash
