Water leak in 3rd row area
Old Jul 1, 2018 | 02:24 PM
mcioci's Avatar
Default Water leak in 3rd row area
water leaking into both sides of where 3rd row is located. Leaking from both left and right headliner. Dripping down from plastic where headliner lays in. I siliconed both rear corner markers but that didn’t fix issue. Front and 2nd row seating areas completely dry. Has anyone had this problem?
Old Jul 1, 2018 | 03:32 PM
hummer_on_fumes's Avatar
I had this exact same issue, I silicone'd all the rear lights including the 3 red marker lights above the tailgate, it has not leaked since. My H3 had rear drain tubes for the sunroof but I'm not sure if the H2 has rear drains or not
Old Jul 1, 2018 | 07:12 PM
I know some have had the bolts that hold the roof rails on leak as well as seam leaks under the rails. The rails are not easy to remove either.... Might be when they are new but they were not easy on my 2003.
Old Jul 1, 2018 | 09:46 PM
mcioci's Avatar
I siliconed the 3 red lights on the hatch I wil wait for another rainstorm to see if helped. If not, check the corner lights again then maybe look at the rails. Thx for the input.
Old Jul 2, 2018 | 08:16 AM
Also check the gasket on the hatch opening itself along with the hatch wiring tube thing just to be sure...
Old Jul 2, 2018 | 09:21 AM
mcioci's Avatar
I wasn't thinking hatch because I could not see how the water would leave the hatch and make it inside but I guess anything is possible with water. Thanks for the input.
mwoolard
New Member Area
Mar 20, 2019 07:36 PM
Toreador
Nov 29, 2015 09:05 PM
JpaangLLC
Oct 25, 2009 01:47 PM
slackwaresupport
Jan 7, 2009 07:43 PM
jad568
Apr 3, 2008 10:35 AM
