Using wheel spacers with 35" MT's?
Old Nov 3, 2008 | 10:44 PM
Brodie's Avatar
Default Using wheel spacers with 35" MT's?
Hello All,
I recently added 35" Toyo MT's to my 07 H3 and cranked the torsion bars about 2.5 turns to raise the front end up a bit. I'm still experiencing a slight rub on the sway bars. Will utilizing 1/4 wheel spacers cure the rubbing issue without having to extend the wheel studs? I don't really want to go with a full 1 inch spacer as of yet to cure the issue since I have a set of 1/4 spacers on hand.
Mr. Gasket 1/4 Wheel Spacers 6x5.5
[IMG]local://upfiles/3607/AEFDA56CFF80400F8EBDB63FD3B3ABE4.jpg[/IMG]
Old Nov 4, 2008 | 01:30 AM
lucky19942001's Avatar
Default RE: Using wheel spacers with 35" MT's?
sorry no idea but i am sure some1 will come along that does. good luck
Old Nov 4, 2008 | 06:02 AM
D VADER's Avatar
Also keep in mind that spacers puts an extra load on your wheel bearings.
Old Nov 4, 2008 | 07:58 PM
veves's Avatar
are you gonna add the spacer?
i was thinking about it just for looks
Old Nov 5, 2008 | 01:06 PM
It is just the foreign tires that rub! [8D][8D]
Here is an idea, how about do not turn your wheels so sharp unless absolutely necessary! Remarkable....problem solved.
rlad10
Jun 29, 2011 01:49 PM
vinny
27
Jan 7, 2011 08:11 AM
chukwagen
Feb 18, 2008 03:00 PM
wilsoada
Dec 7, 2006 09:26 PM
