under $200 roof rack
Old Mar 22, 2012 | 11:25 PM
  #41
kshummer's Avatar
If there is a hump you can use your carriage bolts to space them up.
Old Mar 23, 2012 | 11:40 AM
  #42
drtom's Avatar
Banned
if u zoom u can see the mid bolt difference.
thats why its not ez to slide this out the front till all nuts are loose.
it takes a little wiggling.
btw these ARE carriage bolts, not lag screws!.
it took me,(alone) about 30 min to install, then assm cross braces.
i beaks down to 5 pieces
Old Mar 25, 2012 | 11:57 AM
  #43
mr.spooky's Avatar
finally done with the rack. alls thats left is wiring the lights. the rack its self,and the lights was just under 200,,but by the time i add the paint and the wiring for the lights, it will still be under 300. Im satisfied.
Old Mar 25, 2012 | 12:28 PM
  #44
drtom's Avatar
Banned
with all the welding do you have some special rust treatment planned? id like to know what you use and how it works.
also,a close up of the final mounting bolt design. was it ez to put on?
im planning to work up a replacement for my 2x4 special using 2 inck aluminum angle stock but the same layout i have now.
im not a green guy but i sure like the look of your truck. looks army!
Old Mar 25, 2012 | 01:03 PM
  #45
mr.spooky's Avatar
the only rust treatment I got is ALOT of primer and ALOT of paint. The paint that I used was duplicote <? bed liner stuff. It was the same stuff that I painted the grill with. I used 4 coats (4 cans) so I recon thats all of the prevenative maintenence that I can do. The mounts are made of 2X2 square stock. This gave me a good amount of room off of the roof, and with the 2X2, I could get a wrench in there to tighten up the bolts. The way that I attached to the inside of the track can be seen on tha first page, and heres how the attachment looks. It was very easy to put on, but I used an electric boom to raise it above the truck. The measurements was perfect and it fell right into place.
jason
Old Mar 25, 2012 | 07:42 PM
  #46
spooky, looks good! nice work!
Old Mar 25, 2012 | 09:12 PM
  #47
mr.spooky's Avatar
Thanks! My next move will be to make some sliders. probabally from 1 1/2" black iron pipe.
jason
Old Jun 3, 2012 | 12:09 PM
  #48
thedave8's Avatar
LIKE IT!!!!!!!good job!
SedonaBoundH3
Apr 5, 2012 02:27 PM
Caraddict
Apr 22, 2011 07:13 AM
jeffwhiteis
Jan 7, 2011 07:15 PM
FloridaFeMan
20
Feb 18, 2010 08:19 AM
waikoah
Aug 9, 2008 11:30 PM
