Truxxx Kit Question
Old 11-05-2009, 07:57 PM
dangle's Avatar
Default Truxxx Kit Question
Okay so I just got my Truxxx leveling kit and tried installing. I got to the first side and unbolted the TB bolt as per instructions.
http://www.truxxx.com/pdf/403010.pdf
So when I did that, I had the bolt all the way out and put the spacer on the bolt and could not screw it back in with the spacer because there was not enough treads. I guess the tension was released and that big of a spacer was not going to work. I realize that I may be confused or just having some issues here. I had jacked up the hummer to try and make things easier - still no success. Bolted it back together and figured I will wait until tomorrow when I call and see what I am doing wrong.
Does this sound familiar or can someone help out someone who is confused.
Old 11-05-2009, 08:59 PM
dangle's Avatar
figured it out - I need a special TB removal tool
Old 11-05-2009, 11:15 PM
largemouthbass's Avatar
should have just cranked your tb's up and got new shocks and bumpstops.
those leveling kits are a waste of money.
Old 11-06-2009, 02:08 AM
JGBB04's Avatar
yup should've just spent the money on new shocks & bump stops!! this has been hashed out many a time on several forums.
Old 11-06-2009, 10:21 AM
Truxxx sucks.
For anyone even thinking about leveling kit keys .... I am selling lunar condominium units, PM me for details and send $$, you obviously do not mind throwing it out.
Old 11-06-2009, 07:08 PM
marksteven's Avatar
If i was you , i would clean up the parts and take them back to whoever conned you into buying it. then do a search on this forum on how to adjust your torsion bars to level your H3 without any aftermarket CRAP!
Old 11-06-2009, 07:36 PM
bearcsa's Avatar
I have the same kit. I get vibration if I crank them over 23.5".
Old 11-06-2009, 08:07 PM
marksteven's Avatar
Remove the kit, adjust to 23.5 , get an alignment and your done with wander and vibrations.
Old 11-07-2009, 01:05 AM
2wheelmonster's Avatar
how much did the kit cost?
Old 11-07-2009, 07:58 AM
marksteven's Avatar
Probably costs more than taking an H3 to a dealer, having them crank the torsions then aligning it. mine was done before i picked it up new. they charged me a wopping 75.00 !
Quick Reply: Truxxx Kit Question
