Transmission cooler installed ... Leak ???
Old Mar 7, 2015 | 05:39 PM
H2Miami's Avatar
Default Transmission cooler installed ... Leak ???
Just finished the trans cooler .. I got leaking on both fittings .. What should add to the thread , Teflon tape? .. Would this hold with the transmission fluid and heat . thx
Old Mar 7, 2015 | 06:42 PM
Synthetickiller's Avatar
I came across this link: Click me!
I don't believe the factory uses anything besides a gasket, right?
There seems to be sealers for this purpose if you want to go that route, but it doesn't seem to be necessary. Check the torque. Over or under-tightening could cause a leak.
Old Mar 7, 2015 | 10:06 PM
H2Miami's Avatar
@Synthetickiller .. tHANKS but the problem is with the cooler fittings , I just remove it and re-tight the fittings . will do a double check tomorrow ... THX
Old Mar 7, 2015 | 10:36 PM
OH I SEE! Literacy is such an important thing, lol.
So it's the thread on the fittings that's partially stripped? Well, I'd assume teflon would work, but be careful that it doesn't get into any part of the transmission. That could become an expensive thing to fix.
If you can hold off, get some fittings that fit properly. I'd deal with slight leaks for a bit & do it right the first time. I'd hate to hear a $40ish problem becoming $1000s.
Old Mar 9, 2015 | 08:22 AM
calif phil's Avatar
Brushing a little liquid teflon pipe sealant on the threads will likely cure the leak if the threads are not stripped. Permatex makes a good product that you can get a NAPA or Carquest.
Old Mar 9, 2015 | 10:57 PM
H2Miami's Avatar
So far is not leaking anymore , I just re-torque the fittings ..
Btw anyone doing this be very careful while installing the fittings you need to use another wrench on the cooler aluminum nut or this will be twisted
Why do I know it happens .. Guess what
Old Mar 11, 2015 | 09:52 AM
Torque specs matter, apparently!
Hopefully, it stays leak free.
Mind posting a pic of the work?
Old Mar 12, 2015 | 07:40 AM
H2Miami's Avatar
I got to double check but I see not torque specs on the box or instructions . I'D torque using the old school method ...
ALL THE WAY
greg260
Aug 17, 2013 04:28 PM
Rob4092xx
Aug 8, 2009 08:04 AM
josh1899
Aug 13, 2008 08:48 PM
mastercraft88
Mar 23, 2008 01:20 PM
anthony42376
May 21, 2007 11:59 PM
