Transfer Case Fluid Level
That would take a major redesign. The speed sensor needs to be located where it can get a reading off the speed sensor tone ring, mounted inside the t/case.
My TC has a green sticker or mark by the fill port so if it goes to the dealer (not likely) they should (again, not likely?) know to check. I'm going to use a paint pen to add the instructions to the TC by the fill plug so if it goes to the local Jiffy Quick Lube place again and the kid decides to check fluids he might then know why all that "excess" fluid was in there (and hopefully put it back in! ) Grrr!
I have heard that the low fluid in the TC is a problem if you are out wheelin in 4Lo, not as much for normal use?
They need to read the manual for the correct procedure, unless they do a lot of these.
It is correct. If the vehicle is never off-roaded, there is a good chance the shift forks will not receive any damage.
i would think that the plastic forks broke mainly because they were plastic.
dwaxman1
10-05-2016 07:57 PM
triblk6spd
32
03-05-2012 03:26 PM
h3carlos
01-25-2012 06:39 PM
Zipthelipp
02-12-2011 11:05 PM
